Re: Starter removal question
chum
03-11-2002 17:50:43
The easiest way to get this starter out, without breaking the drive housing, is to split the tractor and use a piece of brass or oak wood and drive it out. Another thing to try before you take it out is put a jumper cable from the ground side of the battery to the starter housing and try it. I had one of these same starters on a '59 D-14 do the same thing. It was losing its ground between the housing of the starter and the drive end. It was solid rust where these two pieces came together. My starter would run good when I tested it in a vice, but would not operate in the tractor because of this rust on the housing. If you have any other questions, just email me. I could probably give you a few more tips on this particular starter. Chum
