Re: WD hydraulics
Author |
Tom
03-10-2002 04:37:49
Randy, The hydraulic system on the WD is high pressure - low volume. This makes the system incompatible for some applications, but it will work - only very slowly. You will have to add a spool valve; the location selected is your choice for ease of operation. Route a pressure line from the tractor hydraulic pump (you can tee into a line going to the lift cylinders) to the input side of the spool valve, and route the return line from the spool valve back to where you check and add hydraulic fluid. Just below the cap you will see a pipe plug that can be removed and this is where you connect the return line. Use the largest diameter hose possible going from the pump to the spool valve to provide for maximum oil flow. I used this system for a loader with double acting cylinders on a WD45 25 years ago. The performance was extremely slow and unacceptable when loading lime in a spreader. But maybe for operating only one cylinder it may meet your needs. If your needs require a responsive system that reacts quickly, you will have to add a pump. I initially added a pump kit to the distributor drive, but the drive gear would not handle the stress and load from the add-on pump. Eventually, I connected a 10 gpm to the crankshaft and this solved all the problems. Adapting the pump to the crank was challenging, but a little fabrication here and there and it was on and working! The results are very satisfying and I still use this tractor today. If you add a pump, you may have enough volume in the tractor hydraulic system reservoir. If not, you will have to add a tank. Best wishes!
Bryan Smith
03-11-2002 11:30:05
Re: Re: WD hydraulics in reply to Tom, 03-10-2002 04:37:49
YT has a conversion kit for a D series AC that reportedly includes a pressure reducing valve to get it down to 2200 psi. The kit costs around $230 - you could probably start with this and adapt it to your WD.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
