Re: Which Parts Cross; If any?
Doug
03-08-2002 20:11:46
Yes, sheet metal from stlyed WC (pre WD) is interchangeable, unless the WC does not have a starter, in which case the sediment bowl would be right above the start (not good).
'48 was the first year for WD's
Going forward almost all later WD and WD45 parts will fit except transmission which changed in '53(has curved gear shift lever and helical gears after that).
There are even some early (series 1 and 2) D17 parts in final drive, brake and engine area that will work.
