Company Logo (800) 853-2651 Shop Now
Re: Allis B
Harold H
02-05-1999 17:44:52
Model B, firing order 1-2-4-3, rpm 1850, compression # 84, valves; seat angle intake 45, exhaust 45, clearance intake .010hot, exhaust .010 hot, static timing 30 deg, impluse lag angle 30 deg, mag gap .020, 14mm spark plug, gasoline AC 45 or AutoLite AN7, distillate AC 47 or Autolite AN9, gap .030 to .040, carb float level 1 5/32". Has 125.3 cu in 3 3/8 x 3 1/2 engine rated at 1400 rpm, 1850 max no load rpm. Crankcase capacity 3 1/2 qts, transmission case 2 gals. Nebraska test # 439; 22.25 belt hp, 19.51 db hp, chp 22.87 belt hp, 20.60 db hp. Shipping weight 1400 lbs.
Harold H
dan wood
02-27-1999 16:12:22
 Re: Re: Allis B in reply to Harold H, 02-05-1999 17:44:52
your model B timing scale is located on the side
of the flywheel and is viewed through an access
hole in the side of bellhousing.i can't remember
which side and am too lazy to look,but i think
its the right side.at least it is on mine,the latter added to prevent purist flak good luck
John R
02-27-1999 14:56:14
Harold,
The information you provided is great. Is the transmission oil just plain 90 wt gear oil?
Also, can you describe the oil filter system on a B? The B I have has a filter with the threaded portion facing down and some plumbing parts that connect to an oil pressure guage. To get the filter and pressure guage assembly to draw oil, you have to prime it after the engine is running. It does not look like original equipment. What is it supposed to look like?
Today's Featured Article - Talk of the Town: Removin Broken Bolts - by Staff. Another great discussion from the Tool Talk Discussion Forum. The discussion started out with the following post: " How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt. " ... [Read Article]
Latest Ad: IHC McCormick Deering WD-40. WDC-516. Engine also is serial number WDC516. Vertical injector head. On rubber. Round spoke rims. Starts and runs nice. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
