Re: D14 vs. D15
Bryan Smith
03-07-2002 06:03:04
Side panels may interchange. Not sure if hood panels will - we moved a loader from a D14 to a D15 Series II and had to add 1" to the loader frame cross bar going over the gas tank, so the D15 is a hair wider somewhere (either front frame, rear axle points, or both).
Both had a 149 cubic inch engine (gasoline), so perhaps the carb and starter would interchange. The only way to know for sure is to look at a parts manual for each tractor and see if the part numbers are the same. Tyr posting the part numbers from your parts manual for the D14 and see if someone with a D15 parts manual can help you out (I'm going to buy one but just haven't gotten there yet ...)
GeneD14
03-07-2002 07:22:19
 Re: Re: D14 vs. D15 in reply to Bryan Smith, 03-07-2002 06:03:04
Hood panels and grill are bigger on a D15, they won't fit a D14. D15 starter is 12v a D14 is 6v. Later model d15's had a 160 ci engine and taller fenders. Even the D15 with the 149ci engine ran at a higher rpm and compression ratio than the D14, producing more HP.
steve
03-07-2002 19:43:26
 Re: Re: Re: D14 vs. D15 in reply to GeneD14, 03-07-2002 07:22:19
the D14 was actually made first, up till 1960. It was 6 volt positive ground. The D15 took over in 1960 and was converted to 12 volt positive ground. The tractors were no built at the same time. The first D15 used the D14 engine, but they were 12 volt by 1960. Dont think 14s had factory 12 volt, but the last few off the line in 1960 may have.
Jeff
03-08-2002 10:01:33
 Re: Re: Re: Re: D14 vs. D15 in reply to steve, 03-07-2002 19:43:26
This tractor was bought new by us and was 12 volt ne
Doug
03-08-2002 20:28:33
 Re: Re: Re: Re: Re: D14 vs. D15 in reply to Jeff, 03-08-2002 10:01:33
Fender brackets are taller for D15 to accomodate larger std tire size.
Jeff
03-07-2002 15:16:20
We have a 1960 D-14 that is 12 volt
