Re: 12-volt conversion
Steve in NJ
03-05-2002 20:37:48
Big Don,
I've been reproducing new replacement wire harnesses for the B,C, Model tractors with the 6V system. Right now I'm in the process of putting together a 12V conversion with all the poop you need. Should be done in a couple of weeks if your not sure of what to get for parts. The kit will also come with a new bracket to mount the 10SI alternator to the B's engine block which I plan on designing to work with the stock adjuster arm on top in order to make it a snap installing. Just in case you were interested....
