Re: Hard starting B
Ron
03-05-2002 13:03:22
Tyler, unless the valves are set too tight, I would think it is the ignition.. Once started, the "B" should spin right over on a re-start.!! Mags can be Great, and they can make you crazy..!! Above all---make SURE it is DRY, inside, and out..!! Starting a cold damp engine will cause moisture to go into the Mag and condense IF the engine is not Warmed up good to dry it out.. Over-nite Dew was the cause of many late starts for us.!! 4:30 in the morning trying to start them, and all they wanted to do was Back-Fire...Like a TON of Dynomite..!! ALL the Neighbors were awake, those mornings..!!!!
