Re: Allis-B Block
Butch (OH)
03-04-2002 14:46:16
Hello Jan, I hope I am not just adding confusion to the different answers below but Dick L is correct and so is Bryan. The first couple years of Bs had a smaller bore, but most were changed at overhaul to make them 125 CI. Most CAs had pressure lubricated rods and a drilled crankshaft. B and C tractors had holes drilled in the cam to spray oil towards the rods and a non-drilled crank. The B and C rods have two funnel shaped holes to direct oil to the bearings. If a person was to use CA rods and cam with a B-C crank he would have little to no rod bearing lubrication. To anwer your question, Yes you can put ALL of your B internals in a CA block. If you mix and match things keep the rods,crank and cam together from either motor and you will be OK.
