Company Logo (800) 853-2651 Shop Now
Re: Looking For Wide Front For 1954 CA Possible Purchase
cdmn
02-24-2002 22:11:42
You can use the wheels, hubs, bearings, axle nuts. Probably some gears and other parts inside the housing. I wouldn't tear it apart, though. Just keep it in case you want to go back to original. Sometimes a narrow front is better than a widefront. If you've broken the housing, then salvage what you can.
Since this is a high demand item, a complete front end change-over from a salvage yard would be around $400.00 plus freight. If bought sight unseen, which I wouldn't recommend, expect that there will be welds, bends, wear, etc. You must have the correct frontend steering gear and housing assembly in the package. A Model C will fit, but is different.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: one 12.4X32 radial tractor tire on a john Deere 8 bolt rim. has some liquid within. Need to move its in my way as I do not have a JD to use such. Make me a good offer, and its yours. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
