Re: wd runs fine then misses
Ron
02-13-2002 12:35:04
Could be the coil, or the condenser.... Could be a plug wire, or plug, too... Could even be that the valves need re-adjusted...the rockers may need to be removed, and the valve stem end ground or filed to a non-worn condition....otherwise they are hard to set accurately.... One thing I CAN tell you for sure...If there is just ONE drop of water in the sediment bowl, ours will start missing..... .!!! Don't ask me why...I don't know....always have, and we have had these since 1955, and 1957..!!
