Re: Sleeves sitting up!
Butch (OH)
02-11-2002 14:30:28
I too noticed that the TISCO o-rings are a little smaller diameter, but I have several engines running with them installed and no prolems so far. Over the years, I have fixed several leakers for people, most of them were do to rusty, dirty bores in the block. One was due to twisted o-rings.You seem to have to cleaning part well in hand, after you install the o-rings and have the lube applied, insert a pick under the o-rings and take it around the sleeve several times. That will take any twist out of them. Like Dick said, I don't believe that 010 stick out will cause problems. I just did a B with .008 and it sealed up fine. Good luck
