Re: oil presure wd45
Dave Grubb
02-07-2002 06:45:41
You are above normal if you are sure your gage is indicating accurately. The tractors usually run 9 to 12psi. Someone may have shimmed the oil pressure relief valve a little. A tractor with the AC gage should have pressure indicating on the 'o','r', or 'm' according to the operators manual. I have checked the indications of my AC gage at the 'o','r', and 'm' indications and they are 3, 6, and 9 psi respectively. For best results use a gage wherein the center 50% of the gage span is used to provide the indications you are concerned with.
bill annett
02-07-2002 13:26:15
 Re: Re: oil presure wd45 in reply to Dave Grubb, 02-07-2002 06:45:41
Thanks for the information, Dave. Pressure guage on my tractor isn't an AC guage, it goes from 0 to 100 psi. I just fired it up and it's pretty close to 12 psi. I guess I should buy a real AC guage. Thanks, Bill.
