Mine had the same "problem" when I got it. The previous owner had wire-tied the control down. Turned out that that the pump wasn't setup for the right job. The pump can be set for all sorts of jobs so be sure that it is set up correctly for the job you need to do. There should be a decal on the battery box just above the pump that shows you how to set the pump up. The pump has four manual adjustment knobs. The most commonly used set up for me is the hold position setting. The lowest knob on the side of the pump is the drawbar adjustment ("A"). It is used for pulling plows and the like and gives traction control. Turn this knob all the way into the body detent locking the plate into position. (If you have a linkage to the drawbar you may want to remove it.) The second knob is on top of the pump on the side linkages. This is the hold position adjustment ("B"). Turn it so that it locks the two plates together, allowing them to move as one. The third knob is also on top but on the front of the pump's hold position valve. This controls the delay lift ("C"). Turn it all the way out until it hits its stop. The last knob is on the front of the pump about half way down. It controls the rate of lift ("D"). Turning it all the way out gives you fast lift. All the way in is slow lift. (I have mine set about halfway.) Once you have the pump setup for the job you want to do, you need to adjust the linkages. (I'm going on memory here so hopefully someone will check me on this.) First with the tractor off move the lift control to the full up position. There is an adjustment just under the gas tank on the large linkage to the hydraulic pump. Loosen this and push the linkage down to take all the play out of the pump and retighten. Move the control back to the down position. Turn the second knob I mentioned above (the hold position knob "B") into the detent in the body of the pump separating the two plates and locking the inner plate to the pump. Now start the tractor and raise the lift to max height and shut the tractor off with the control still in max lift. Stand on the lift arms and slowly lower the lift control until the pump releases completely. (This should be about halfway down the quadrant.) Now, being careful to not move the position of the control, go back to the outer plate and loosen the smaller linkage adjust (which is on the outer plate) so the plate moves easily but be careful not to move the rod. Rotate the outer plate so that you can turn control "B" back out of the pump again locking the inner and outer plates together. Being careful to not move the control linkages, rotate the plates counter-clockwise until you feel them click into a detent and retighten the small linkage adjustment. You may have to tweak it here and there depending on how worn your linkages are and I don't recall the adjustments for the traction boost linkage down to the drawbar (and don't use them anyway as mine doesn't have the linkage) but that should cure your creep problem. The control may still creep up from full down to the detent but the lift will stay down. (I normally keep the control at the detent anyway.) Hope this helps.
