Company Logo Shop Now
Re: Small setback on C wiring problem-need help again-
BamaDee
01-12-2001 07:33:43
Fred, I'm guessing that your using a multi-meter, perhaps a digital multimeter. You have to be carefull,as to what range you are using (function switch) on the meter ,as you can fry the multimeter very quickly by pulling current thru the meter. Most of them require and external shunt , if your going to measure more than about 500 mili-amps. Remember, an amp meter is in series with the source and load, a volt meter is across the load or source to ground. Almost all ammeters are actually 50 miliamp devices with either a internal or external shunt to give them the desired current range. I'm not trying to be a smart a-- , just don't want to see you fry your meter. Good Luck Dee
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
