Re: C compression
Gary(Ont.)
01-01-2001 05:45:02
Marty
I believe if you multiply the Compression Ratio X 14.7 ( Atmos. Press. )you will get the maximum compression for that engine. Eg. the 125 BE engine has C/R of 4.9 - so its max. compression reading would be 72 psi.The 125 CE engine has a C/R of 5.75 - so max. compression reading would be 85 psi. CA works out to 92 psi.
(WD:81,WD45:95,D15:114psi) Gary
