Hi AC experts, pls help...I've got an AC D17 series I that was working fine cutting hay. Turned it off while taking a clog out of the sickle bar, and go to start it and no dice. It cranks over for a second then stops. A couple times I've heard a beeping sound, but not always. If I turn the ignition again, it'll turn over for a second or two, and then stop, like it's freezing up or doesn't have enough power to turn over anymore. Checked battery which wasn't holding a charge and so replaced it. Still the same with the 1.5 second crank over. Replace coil because I had a new one in the shop, and still the same thing. Anyone know what might be going on? Thank you!
