WD45 power steering hose
770
Anyone have a good source or substitute
info for power steering lines on a WD45?
Thanks to all in advance.
Take the old hose anywhere where they make hydraulic hoses. They should be able to make one.
They make compression fittings you crimp onto the new hose. Then you cut the pipe off the old hose and install it on the new hose.
I have a WD45D with power steering. One hose the fluid is starting to bleed through. I have a.hose machine and intend to make new hoses.
