Allis G no start.
mdm1
05-02-2023 12:21:05
Brief history. This tractor hasn't run since the 90's. Put all new plugs, wires, cap, rotor, points, condenser 12v coil as I am going to convert it. Just running off a 12v fully charged battery. All wiring new. Boiled and cleaned carb. I got it running and it ran really well. Power washed it and the problem began. It starts and runs for a couple of seconds, sputters dirty looking grey smoke and quits. It did this once before and I took the carb off and cleaned it again and it ran great. But now the problem is back. I have spark to all cylinders and the cap and wires are dry. Good gas flow to the carb. Gas is clean. I think the carb needs a new float needle as it will drip gas when turned off. It wants to run but it's all show and no go. Any help appreciated. Thanks
mdm1
05-04-2023 09:23:45
 Re: Allis G no start. in reply to mdm1, 05-02-2023 12:21:05
Ya Hoo! it runs. Since I had another tuneup kit I pulled the condenser and points. Looked at the old points and cleaned them thought I would just give them a try. Fired right up. I really thought it was fuel related.
13fx
05-04-2023 20:42:07
 Re: Allis G no start. in reply to mdm1, 05-04-2023 09:23:45
Really glad to hear that. Way easier than cleaning the carb and fuel tank out.
mdm1
05-03-2023 16:58:26
I pulled the gas line at the carb and drained the tank using a clean white rag as a filter. Everything was clean. Took the carb apart again still no go. I have a kit ordered.
mdm1
05-02-2023 13:56:25
I thought about the gas tank. When I checked the flow to the carb I ran the gas into a clean container to check for particles. I did originally clean the tank out and it seemed to be clean but I know it doesn't take much. As for plans. I have none really for it. I have always wanted one and now I have two. This one came with a woods belly mower, 1bottom plow, sickle mower, and cultivator. You have to love these old tractors or why would you have one?
13fx
05-02-2023 13:18:54
Since the tractor sat for 22+ years I would say it's very likely that the fuel tank is part of your culprit. You said that after you cleaned the carb the second time it ran great.... For a while now the problem is back. I think you are building up fine particles in the carb that come from the inside surface or the fuel tank. Since the G has a small engine mounted on back with the fuel tank on top, try running a different tank to the carb for a little while after you clean the carb again. You also say that the carb leaks fuel after a while so if cleaning of the float needle and needle seat didn't work go ahead and replace them. So what's your plan for the G anyway? they are such weird and fascinating looking machines!
