Allis 200 oil pressure switch location
Joshbraman
05-01-2023 18:43:38
I just purchased an allis 200 diesel. Got it for a great price. I wanted to put in an oil pressure gauge in but I cant locate where the oil pressure switch was located on th block. I found the wire for the switch dangling so Im guessing it might have been removed. I have a 180 diesel i changed out and put a gauge in but things different on this block. Any help would be greatly appreciated.
Joshbraman
05-02-2023 17:52:45
 Re: Allis 200 oil pressure switch location in reply to Joshbraman, 05-01-2023 18:43:38
Thank you. I found were it was behind the filter. It was covered with oily dir5 and hard to see. Hopefully it warms up someday so I can power wash it.
gearheadbill
05-02-2023 05:48:05
The plugs along the oil gallery are all a common eighth inch pipe thread
DrAllis
05-01-2023 19:44:58
Quoting Removed, click Modern View to see Same family of engine block. Oil pressure red light switch is behind the fuel filter just ahead of the starter. There are several small plugs on that side of the engine block that are ALL into the main oil galley.
