Allis C gear lube
David J-WI
04-30-2023 08:25:11
Is it ok to use 80w90 in this tractor with hyd pump?
4wdtom
04-30-2023 08:49:25
 Re: Allis C gear lube in reply to David J-WI, 04-30-2023 08:25:11
With hydraulics use 20 weight engine oil or tractor lube, a universal gear, hydraulic oil.
David J-WI
04-30-2023 11:08:06
 Re: Allis C gear lube in reply to 4wdtom, 04-30-2023 08:49:25
Thank you. Do you know the how much it holds ?
4wdtom
04-30-2023 13:54:03
 Re: Allis C gear lube in reply to David J-WI, 04-30-2023 11:08:06
7 quarts with PTO/hydraulics, should be full to level of filler plug on side to left of transmission with tractor level.
