I need to replace the ring gear on a 1948 C, so went about setting up to split the tractor. When I started moving the rear end away
from the engine the shaft came out of the transmission instead of out of the pilot bearing. So, I think I have two big problems,
how do I get the shaft out of the pilot bearing and then how do I get it back in the transmission? I couldn't be so lucky that the
shaft would just slip back into the transmission. Any suggestion greatly appreciated.
Gary
Gary
