Recently got rain water in gas tank. Dealing or dealt with that. During the draining process I noticed that my throttle doesn't close-off when the lever is in its version of the 12-o'clock position which is more like 1 o'clock. Should the fuel flow be completely stopped? Changed the linkage rod setting 3x and there was still fuel running. Only stops completely if the valve at the fuel bowl is closed. Is this normal?
The 'linkage' was welded with a U-piece at some point to accommodate a power steering unit that I wish still worked. That's why 1 o'clock is lowest fuel. Photo shows closed throttle 1 o'clock position.
Thanks again
Thanks again
