Model C carb
Timmydou65
New User
Should I rebuild this carburetor or just buy a newer one? I am capable of doing either one. What's the consensus?
If the new carb is from the land of almost right that's what carb might be is almost right. The quality of the original is probably better if you can clean it it is likely fine. You may not even need a kit.
I rebuilt the carb and reinstalled. But there is a hole in the bottom of the bowl where it seems a cap should go. Any advice?
