olgentdc
I have done little but tinker with this D-17 because I know something just cant be right with Hydraulics ,There is a relief valve squealing and straining. The pump is building heat in a short time while running. It is a series 4, it has 4 ports for 2 remotes, the loader was removed before i bought it.the rear lift is stuck up.and the control linkage looks to be complete but is all disconnected. I have pushed and pulled and tapped at the levers that connect to valve body with engine off and running and cant get a satisfactory response. What I need is a book for this D-17, and a picture showing linkages for the rear lift and how the draft control is connected.Or at the very least direction as To where i can find a few pages of Info describing the same. Thank You to All that can help Me give this D -17 relief,
