I ve got a d15 that I m trying to get going to use for little chores and such. I m not intending to restore it by no means I just want everything to work like it should. When I got it I didn t have much throttle response and I put a new governor in it and got it to run a good deal better. Had to turn the distributor a bit but it was running good. I took a spark plug out earlier today to see what number it was so I could get new ones and forgot to hook the plug wire back up before I backed it out of the shed. It started and was running just like normal without the one plug wire on. I pulled the valve cover and the valves aren t stuck and the pushrods look to be straight so idk what to do now. Any suggestions??
