How much is involved, on a WD AC
Hood, grill,and radiator come off, split the steering at the u-joint and pull the steering wheel side up out of the way. 4 bolts on the bell housing and 2 under the timing cover. If motivated about an hour of work.
AaronSEIA
The two lower radiator bolts can be a challenge if too many years have gone by without removal. Same goes for the pin that holds the steering shaft into the knuckle.
Not too bad. Radiator bolts were the worst. Gleaner E m code motor going in.
I can have those out in about a minute a side if they aren't rusted tight. 3/8 drive socket and a long extension. There is a hole punched in the frame rail below the bolt. Stick the extension through the hole, then put the socket on. Narrow front works best if you turn the tires to get more clearance for the ratchet.
AaronSEIA
