Power adjust rim lock question
stevieb49829
Do I just tighten the eccentric cams tight, or do I need to reef on them to get them to the over-center end of travel?
And please don't harass me for not painting the rims too :<)
It works best to tighten the one thats nearest the bottom first, then the 2 opp sides, then the top one.
No need to do them in steps
One at dead bottom 6 oclock. Tighten first. Tighten 3 and 9 oclock next. Tighten 12 oclock last.
They should now be tight enough. I busted a good 3/4 socket on my cheater bar, but they are all to the stops now. I think a dab of grease on the eccentric might have helped. I did wire brush the rust off. Whew!
