Allis chalmers 185 leaking transmission oil
gg75
New User
I m new to the Allis chalmers tractor I haven t had it very long but the transmission oil disappears somewhere it s not going in the hydraulics or final drives I don t see it on the ground either I can t figure it out any help would be greatly appreciated
(quoted from post at 10:30:13 08/06/22) I m new to the Allis chalmers tractor I haven t had it very long but the transmission oil disappears somewhere it s not going in the hydraulics or final drives I don t see it on the ground either I can t figure it out any help would be greatly appreciated
Sitting in the seat, the transmission/differential oil level dipstick is to the RIGHT of the gearshift. The hydraulic system is to the LEFT of the gearshift and unscrews several turns. You cannot be losing transmission/differential oil and not be able to see it leaking somewhere. Most common would be the PTO shaft itself. Final drives are separate and outboard location.
Thank you for replying and your help I put 2 gallon in it today to
get it back on the stick the hydraulic isnt gaining any oil I laid
under it its a little wet on the bottom looks like where the pto
bolts to the housing but as much oil as I have put in it it should
be pouring out somewhere
Hydraulic going down?? transmission is then going UP !! That is a common problem. Something is gaining if one compartment is going down.
