WD loader, Freeman model WD-9
4wdtom
I have a WD and have been working on cleaning up, welding up and will be painting a Freeman Loader for it, model WD-9. It doesn't have the two legs or supports that hold it up when taking it off the tractor. Does anyone have one of these loaders and if so could you measure the actual length of one of these tubes/legs? Just the tube length would be fine I can figure out the adjustable screw and foot. Thanks, Tom
I don't know anything about Freeman Loaders but you need your tubes just long enough to drive into it with little adjustment. Level ground will be a big help and if it already mounted you are half way there. Is your WD wide or narrow front? Wide makes legs needing to be further ahead. Of the loaders I have it is never easy since they are outside and between mounting stuff always settles. Cleddy
Thanks for the reply. I have it figured out pretty close. Close enough that the adjustment I build in will take care of it. Wide front end. I know it has to clear the front wheels and is close. Used one of these loaders on a 45 as a kid.
