Allis chalmers 7-24 snowblower
Hey I got this snowblower for free. It
runs and works great except I cant get
her to go full throttle without stalling.
I can't find any ID on the engine but
I've been told it was built by simplicity
back in the day for ac.
It sounds like lack of fuel. Plugged line, tank outlet or filter or dirt/plugged jet or passage in carb.
I'll get more pictures tomorrow. I ran a can of sea foam thru the gas tank and sprayed it directly thru the carb to clean up the deposits or whatever clogged in it. Now she runs at full throttle with no problem. Also replaced the spark plug.
That's a Tecumseh engine.
Model info should be stamped into the top of the flywheel shroud.
7-24 probably means 7HP, 24'' cut?
