One last question about my 7040. I have ordered all the parts for rebuilding the torque limiter. I just got the flywheel resurfaced and I will be putting on the new ring gear.The machinist recommended replacing what -looks like a pressed on bushing or ring on non machined side ,Approx. 5 inches accross. I can't find it in the manual and not sure what the correct name is for this part. Also what is the best way to remove the old.warn out ring. I had no problem removing the ring gear and will try heating the new one in the oven to expand it.Sounds a little crazy but I have seen it done.So basically I just need a part name. Thanks
