AC B wheel ?
Harold C
New User
Allis Charlmers B with cast iron wheels , how to install the tire rim assembley to cast iron wheel ? is there a centin trick?
Yes
If you don't get an answer in a couple days I'll dig out my manual and read up how it fits.
IIRC the four pins are not identical, and one is special.
There are four wheel bolts - two of these are regular bolts - the other two are eccentric bolts. The regular bolts are placed with the valve stem cutout between them - the eccentric bolts are opposite the cutout.
Following is word for word from the manual:
Install eccentric rim clamps last.
The eccentric rim clamp bolts have a cross stamped in their heads. One arm of this cross is longer than the other three, and coincides with the high, or tight, side of the eccentric.
In tightening the two eccentric bolts, turn in opposite directions and as near the same amount as possible. Hold in this position and tighten lock nuts.
