G throttle rod needing help
lti
Need a picture of how that is mounted from engine end to throttle
control and where tha bracket mounts to. Thank you.
See if what you need is in here. Click on the picture to advance to the next picture. If not I can take a picture and add it to this album
Look Here
Thank you... Someone put a Sediment Bowel on the carberator and bent the throttle rod to fit around it. So thats coming off and can put the throttle rod as it should be. Thank you.
