Jona
Also I have a leak in the PTO shaft on the back how do I put new seals in can I just remove the casting with the three bolts and take it off and put the seals in or can I do it without taking that off thank you much
Drive the front wheels into a very deep ditch and remove the 3 bolts, remove the retainer, replace the seal and Oring. If you don't like the ditch, drain the transmission oil and then replace the seal.
