D17 hydraulic pressure
Only series 3 and 4 model D-17's had one hydraulic filter under the battery tray on the right side. WHERE are you checking the hydraulic oil ????? The dipstick is to the LEFT and forward of the gearshift and screws in. This hydraulic compartment holds minimum of FIVE gallons of oil and may take 5 1/2 gallons to be FULL. Did you just change the hydraulic oil???? There are TWO drain plugs you know !!
