What is the value of a 1952 Model WD tricycle type
hbhiron
New User
What is the value of an Allis Chalmers 1952 Model WD tricycle type
with a single front tire? Serial # WD180108 It has a recently overhauled engine and runs very well.
(quoted from post at 16:41:44 05/17/22) What is the value of an Allis Chalmers 1952 Model WD tricycle type
***** That serial number is a later 1954 WD-45. SO, now it's actually worth more if it has a WD-45 engine in it. Where did you get this serial number from ?? the engine block?? or on the rear end just above the lift arm shaft ??
This post was edited by DrAllis on 05/17/2022 at 06:24 pm.
(quoted from post at 18:20:36 05/17/22)
I found the serial number on the left rear of the rear axle housing.
Should I look somewhere on the engine block?
That sounds like the right spot for the serial number. Single front is a bit more rare. I'd say $1500-1800 or so without pictures.
AaronSEIA
So, it is a legit WD-45 chassis built in later 1954. The engine serial number is behind the carb to air cleaner hose stamped on the block. A WD engine will read W-XXXXX. A real WD-45 engine will read 45-XXXXX.
I found the spot on the engine block under the carb and air cleaner. It was rusty, so I cleaned it with some paint thinner to remove the rust. I can't make out the numbers. I'll have to get a magnifying glass and probably some better eyes to see if we can make it out. I did find a casting number above it just below the cylinder head. If that would help, here's what it is: NK16U
There's also a casting number on the lower right side of the block.
It's: AM 3853-21 and just below it is the number "3" if this might help.
Yeah, I'm aware of that. I didn't hold out much hope, but, you never know....I'll take a closer look tomorrow in the daylight (the tractor is sitting outside the shop) when I can see better and maybe one of my guys with a li'l bit better eyesight can look at it also. Thank you so much for your help. Maybe we'll chat again tomorrow. Have a pleasant evening.
