After I rebuilt the engine in my D-17 Series IV, the hand clutch jumps out of high. Doesnt matter if its under a load or just going down the road down hill. It does seem to vibrate a little. Not sure if it did that before or not. I replaced the clutch and in order to get the clutch to fit into place like it was supposed to I had to machine the flywheel a little to get the 1.437. I had the flywheel dialed in to within .0002 when I machined it. Im wondering if the power direct was borderline and if there is a vibration that wasnt there before if that could be it?
We used to have things ballanced in the machine back in the day at the factory that I worked for 29 years. I wonder if that could be done with the flywheel without splitting the tractor. Looks like I'll have to split transmission to get at the power director but I really dont want to split at the engine again. With the loader and all. I cant use it like this. Does anyone do rebuilds/remans with a core charge on these, or do you have to rebuild them on sight and reinstall.
