extremewhitetail
Hey Yall
I just purchased a Allis Chalmers B and cant make heads or tails of a few things.
First, the tractor has a starter and a generator. I have seen other Bs with mounting bracket holes or bolts in the block. My tractor has no way to properly mount the generator bracket. Right now its mounted on a homemade bracket that attached to a bolt near the oil pan. Did this model have a special mounting bracket or do I just need to weld two bolts onto the block?
Second, The magneto has five wires coming out of it. Four for the plugs and one for the coil. I thought the mag provides power so a coil isnt needed. What am I missing here.
Thank You
Thank You
