WD-45 pto seal
The seal around the stubby shaft that the pto shaft hooks to is leaking badly. Am I right in thinking the seal comes out without disassembling the carrier that hangs down below the tractor? The manual looks like it goes into the cover.
You are correct, it is a double seal that you can pull out after you remove the PTO shaft. IIRC it is easier to remove that seal with the front cover removed from PTO housing. Not a lot of prying room with the stub shaft still in the seal.
