WD lift cylinder rebuild
Tim(NY)
The lift cylinders on my '49 WD started to leak, so I got kits from Steiner (ACS3464). The original o-rings were a top, bottom, and 3 rubber middle rings. The kit had the same, except 2 rubber and 2 plastic middle rings. The o-rings seem the same size, and I could get the rubber middle rings into the cylinder bore; but the plastic ones wouldn't go. It also seemed like the middle rings would not go down all the way. The edge on the top ring looks like it won't fit in the bore either, if I can find room for it. Has anybody been through this?
