Robert12345
my left rear wheel is loose 1 to 1 1/2 inches of play in wheel, main shaft had 1/4 inch showing thread on axel so it had been taken
in already,i took the large odd nut off and put two thin washers in front of lock washer and then put odd nut back on and it bottomed
out metal to metal against the lock washer but not up against the wheel. the wheel is still loose. am i up against a step in the axel,
is there an easy fix or is a new axel called for or axel and bearing needed. can anyone steer me to a tutorial fixing this problem. my
right wheel has less threads showing and is tight .
