Allis CA rear spin outs
Im going to pick up a Allis CA and the rear wheels are spinouts and I am going to need to move at least one of them in to load on my 80 trailer. Out side tires measure
84. What size wrench would I need to make sure to. Cary with me to loosen the spinouts. Tractor is not running so I will have to jack it up. Thanks for your help
They are 1/2" square, I think, on the CAs. The D14 was 3/4" hex, so you may want both, just in case. In reality you may want to find a wider trailer to get it home. If the eccentrics haven't been turned recently, the odds are you will have a battle on your hands. Here's hoping you get (or got) lucky with them.
(quoted from post at 20:53:02 06/26/21) Im going to pick up a Allis CA and the rear wheels are spinouts and I am going to need to move at least one of them...... Tractor is not running so I will have to jack it up
Wow, pretty optimistic. Even in the shop, on a good day, with a running tractor, not usually an easy job, unless they've been moved frequently, and recently.
