jhncp
I put the wd back together and tried 2 other gauges and it just registers in the normal range and 10-12 psi on another while cold. I imagine it will drop when it gets hot. I am wondering if I should try taking oil pump out or just be satisfied as is.
A new filter and clean oil wont give a high reading on an AC, thats a scavage oil filter system, its only sending excess oil to the filter, that gauge is only reading resistance of the oil going through clean filtering media, as the filter gets used a few hours it will build up a little resistance and your gauge will read a bit more. Always be sure the filter youre given looks like wound string, not paper, and that the hollow tube is in your filter housing before screwing the new filter on.
