WD Rear Bearing Cap Gasket
Raymog
New User
My Oil Pan gasket set (AGCO 70229860) came with 4 small paper gaskets. Two appear to be the Rear Bearing Cap Gaskets that fit around the felt oil seal. I'm not sure where the other two smaller ones go. Do they fit around the first pan bolt hole? Thanks for any help.
I assume they are what's called the "F" gaskets. WC-WD-WD45 take the smaller ones and the D17-170-175 take the wider/larger ones.
Extremely helpful and explains why I couldn't figure out placement of the wider gasket. Thank you for your help.
