I recently pulled my hydraulic control valve, cleaned it and reassembled it with a new piston seal. It had some junk in it that was effecting the lift. I have it back on the tractor but the valve in the bottom of the assembly is leaking badly and causing the TPH to gyrate. The drawing shows a seal M2.62 x 17.12. Does this seal go around the plug or inside the assembly to seal the cap to the to the plunger assembly? Is this a standard O ring or a special seal? When I took it apart there was a torn O ring around the plug that did not seem to do much, and I did not find a seal inside the plunger assembly....any help in how to put this back together would be appreciated!
Thanks, Mike
Thanks, Mike
