Allis 7000 Hyd Pump
Bobl1958
Need to replace the pump. Is this pump the single or dual pump? Thanks - Bob
Had a young Allis mech come over and check
it out. The tractor sat for a few years.
He changed the filter and re-filled that
sump. Tractor still has no power steering,
wont move, no three point. I wasnt home to
see what all he did, but he told me the
pump was bad.
Well, he should have suggested that the pump be disassembled to see what's wrong before replacing the whole pump. It might just need a shaft seal that is sucking air.
So I guess DrAllis this old pump would be for sale if you are interested. You can let me know. Email open.
I haven't talked to the Mech and he is in the field planting as we are all way behind here in Central KS. I am in the hay field just as far behind, so haven't had time to mess with it either. I would like to get it running to use it on a rake, but neither of us have the time. Could be something simple, but I have the pump in hand if not. Thanks
