Rideemright
New User
I recently purchased a AC 6080 and it came with a 1000rpm pto attachment. Up until now i never needed it. I have a mower that i need to pull with it that is 1000rpm. So i remove the 540 shaft and noticed on the back center it has a hole drilled about 1/2 deep. The 1000 does not. So i mount it anyway as it did match up. I noticed a pin comes out and into the rear of the shaft when mounted but because the 1000 is flat on back with no hole the pen just compressed in and now will not engage pto when lever is pulled. Does anyone know what i can do to correct this issue?
