Allis Chalmers Loader Tractor for cheap
Might be a 60 industrial, I think same engine as D-15. For the price asked I would jump on that if I was close.
(quoted from post at 03:33:05 05/20/21) Might be a 60 industrial, I think same engine as D-15. For the price asked I would jump on that if I was close.
I don't see a 60 Industrial listed in Tractordata.com
Where is theModel number located on this tractor?
Is this the plate marked with red arrows?
It is basically a series 2 D-15 farm tractor, with the 2200 series (200 cubic inch) 4-cylinder engine, which is little brother to the 6-cylinder 301 engine used in 180-200 tractors. Newer than 1965 for sure. Probably closer to 1970. That's a shame, an injection pump problem that isn't dealt with and now you have what was a good tractor turned to rusty forgotten junk....
(quoted from post at 20:18:59 05/20/21) It is basically a series 2 D-15 farm tractor, with the 2200 series (200 cubic inch) 4-cylinder engine, which is little brother to the 6-cylinder 301 engine used in 180-200 tractors. Newer than 1965 for sure. Probably closer to 1970. That's a shame, an injection pump problem that isn't dealt with and now you have what was a good tractor turned to rusty forgotten junk....
I talked to the owner and he said they had another tractor they sold that was not running. So if I understand the guy said they took the IP off this tractor and let the guy try it to get his running. So it's available if I buy it.
Let me clarify....the chassis is a basic series 2 D-15 with a shuttle clutch. The front nose shell has also been beefed up and is different that a farm tractor. The main hydraulic pump is under the radiator.
