Carb on Allis 90
banjoman09
Also I would like to find a rebuilt carb for my tractor- needs one im sure. It is a Bendix...anyone knows who sells these? or even a Kit... Thanks
Had that problem a few years ago with a 190 that I guy had me work on for him. This site rebuilt his carb for him and I got it up and running form there
AGCO parts shows Holley was used prior to S/N 16869 and Zenith starting with S/N 18869 and after. You may have better luck looking for Zenith (Zenith, Bendix, and Stromberg are related) . It looks like it may be a Zenith 13303 or 4021805. Standard Motor Products shows their Hygrade 1669 kit for that carb. The 13327 carb this site has maybe a replacement. Zenith and the 13303 and 4021805 numbers will get you results on internet searches for carbs and kits.
Probably won't make any difference on a "repair kit", but a 190 has a different carb than a 190 XT. So, which is it ??
The carb on this tractor is original as my Great Uncle bought the tractor new....the carb says Bendix/Zenith.
It looks like the AC carb # 4022025 used on the 190, G2500 engine was a Zenith 13327.
And it looks like the AC carb # 4021805 used on the 190XT, G2800 engine was a Zenith 13303.
AC 190 parts book shows the same kit numbers for both Zenith (Bendix) carbs, as does the Standard Motor Products catalog.
Is there a small brass tag (attached with a drive screw) anywhere on the upper body? That will have the ID info, if it is there.
Bendix carbs were part of Zenith, so both names could be on it, but it is called out as Zenith in the AC parts book and generally at repair and replacement sources as well..
