Allis 90 - 1967 Model
banjoman09
Please tell me why my 3-point arms come UP when I start my tractor and my lever is in nuetral position? I have to shut off
engine to get them back done- hard to use this way! Just has done this sitting over winter- didnt use it for a few months.
Thanks
Probably your traction booster valve is sticking. It is on the valve stack under RH side of floorboard. I can't remember for sure, but it the valve spool that doesn't have a linkage rod connected to it. It is either the outer or inner section. It will have an arm that pushes against the front of the valve spool, not physically connected to it. Remove the cap on the rear side of the valve held in place with 2 allen headed bolts, shoot it with penetrating oil, and use a wooden hammer handle or something similar to get it working back and forth.
The two levers at the rear of the console control must both be DOWN. That is where to start. If they are down, then you have linkage issues under the platform.
